VHF/UHF capabilities added to Super Stations #1 & #3
Posted: Thu Feb 25, 2021 12:40 am
Today I tried to add VHF/UHF capabilities to Super Station #4, but the Stridesburg HF Multicoupler that feeds all four SDR's from one antenna feedline doesn't pass VHF/UHF signals without a +28dB loss. The plan was to place a diplexer in front of the multicoupler to allow both the HF antenna and the newly installed 2m/70cm vertical feed the 4 SDRs. A quick test proved the losses are too excessive, so the diplexer was placed in my house where Super Stations #1 and #3 reside. A simple PL-259/SO-239 Tee is used to share the antenna, so there is a 3.5dB (~1/2 S-unit) on VHF/UHF, but it is what it is. If I didn't tell you, you probably wouldn't know it! Station #1 HF antenna is shared in the same way between the two SDR's, and I haven't fielded any complaints yet.
So... if you are in the need for VHF/UHF listening in SE NH (FN42mw), in order of best server to an OK server:
Super Station #4 Airspy HF+ (dual port) and Airspy R1 on an X-200 up ~65' AGL on tower on a 243' MSL hill, so antenna is at ~308'MSL.
Super Station #3 Airspy HF+ (dual port) via a diplexer on a Diamond X-200 in attic of house at ~ 250'MSL
Super Station #1 Airspy Discovery on same diplexer and antenna above
Attached images show the difference in signals (and QRM) via the Airspy HF 2 port on the two different antennas/locations, while monitoring 132.050MHz, Pease Tradeport ATIS at 13.5miles to the NNE. The clear winner is Super Station #4 due to it's height on a tower, almost line of sight if it wasn't for the tall pine trees 500' north of me.
I have a suspicion that the ADSB server running in attic on a Raspberry Pi via Ethernet connection is causing the QRM on Station #1 & #3 VHF since the antenna is ~25 feet away. You can clearly see how weak the ATIS is and the numerous vertical QRM lines.
Home of the ever expanding Super Stations in NH, USA
