Is the BladeRf tested and intended to work
Posted: Thu Mar 11, 2021 3:33 pm
by richhas
I have a basic question. Is bladerf support tested and verified as part of your product release process?
Is it even intended to work? If your team does not do that verification work, who is responsible so I might contact them?
Is help needed to test that functionality? Might be able to help.
Who is responsible for the BladeRf "plug in" dev - contact please so I might engage.
Rich
KI7ZBS
Re: Is the BladeRf tested and intended to work
Posted: Thu Mar 11, 2021 8:37 pm
Hi again Rich
There is no team. SDR Console is all the work of one man, Simon Brown G4ELI:
https://www.dit-dit-dit.com/
Simon is active on here but also does commercial programming so he may just be busy at the moment with other stuff. Don't forget SDR Console is offered FREE! Well, it's actually donationware.... if you get it working with your hardware you will most likely wish to donate as the program is excellent.
I am sure Simon will pick up your thread here and offer some information. Maybe just keep monitoring for a while and he should come along!
Best
Posted: Thu Mar 11, 2021 8:42 pm
Some further drops of information (sorry, nothing very illuminating) but seems no TX support for BladeRF according to the table (if it is up to date):
https://www.sdr-radio.com/transmit
Also:
https://sdr-radio.groups.io/g/main/topi ... f/28120691
Posted: Thu Mar 11, 2021 9:09 pm
richhas wrote: ↑Thu Mar 11, 2021 3:33 pm
Rich
KI7ZBS
Rich,
BladeRF v1 should work, but receive only.
Posted: Fri Mar 12, 2021 5:20 am
by richhas
Simon,
Is there a "public" plugin api and doc? Is the existing bladerf support src available for reference and/or extension by - in this case me?
Not sure where to look on your site.
"No" is a fine answer.
Best
Rich
Posted: Fri Mar 12, 2021 5:48 am
richhas wrote: ↑Fri Mar 12, 2021 5:20 am
Simon,
Best
Rich
No is indeed the answer. I just don't have the mental energy to support this at the moment, but may provide a full source code so you can at least add support for s SDR receiver.
A good example could be support for the Airspy or SDRplay.
Posted: Fri Mar 12, 2021 7:45 am
by richhas
Understand - been there - just retired after almost 50 years deep in it.
Source would be great. I have an SdrPlay... So a fully functional example with source would be a grand place to start if that works for you.
Posted: Fri Mar 12, 2021 8:02 am
richhas wrote: ↑Fri Mar 12, 2021 7:45 am
It's not going to happen soon. This would really tie up my time, then there's ongoing support etc., then the associated legal issues.
Posted: Fri Mar 12, 2021 8:15 am
by richhas
Totally understand. If doesn't fit, it doesn't fit. My email is
richhas@hasha.org if things open up for you. If in any way I could add some value back towards your direction in exchange, I'd be open to that.
Thanks for the consideration.
Rich
