Page 2 of 2
Re: HL2 TX meters issue
Posted: Tue Aug 17, 2021 5:18 am
Max wrote: Mon Aug 16, 2021 10:40 pm OK, trying to reproduce issue (without any luck) but now I've got something odd going on with the meters. Just realised that will SDRC at idle and no SDR started, I see the same TX meters in the TX DSP as you Roger. But once HL2 is running, the meters change and I lose the two meters "Drive" and "VDD". I'm not sure they are of use in HL2 anyway are they?
A clue perhaps Simon? See attached screenshot of what my "normal" looks like compared to Roger.
Max,
What you see is correct - when a radio is started the meters which aren't needed are hidden. Seems that on some systems this doesn't work :( .
Posted: Tue Aug 17, 2021 2:49 pm
NP Simon. Thanks for confirming. Just Roger to sort out then!
Just for info I've never seen the same issue as Roger in the many months of firing up HL2. I also tried enabling Ext Radio panel like in Roger's screenshot but made no odds here.
Posted: Tue Aug 17, 2021 4:04 pm
by G8VLR
Just one thing to mention the external radio is actually off in my screenshot...if that were likely to make any difference.
Posted: Tue Aug 17, 2021 4:52 pm
G8VLR wrote: Tue Aug 17, 2021 4:04 pm Just one thing to mention the external radio is actually off in my screenshot...if that were likely to make any difference.
Am sending you a Private Message with a kit to test.
Posted: Wed Aug 18, 2021 11:31 am
by G8VLR
So today all the meters work! Nothing has changed with Hermes or my pc. I will download the kit, Simon and next time it doesn't work I will use it and send the data.
Many thanks,
Roger.
Posted: Wed Aug 18, 2021 11:44 am
G8VLR wrote: Wed Aug 18, 2021 11:31 am So today all the meters work! Nothing has changed with Hermes or my pc. I will download the kit, Simon and next time it doesn't work I will use it and send the data.
Many thanks,
Roger.
Thanks - I would like to see the logfile, this will help me understand where the bug was.
Posted: Fri Aug 20, 2021 11:21 am
by G8VLR
Log file sent.
Regards,
Roger.
Posted: Fri Aug 20, 2021 11:53 am
G8VLR wrote: Fri Aug 20, 2021 11:21 am Log file sent.
Regards,
Roger.
Roger,
Please attach it here. I don't know where you sent it :( .
Posted: Fri Aug 20, 2021 4:32 pm
by G8VLR
Simon, it was in private messages but I have reattached it to this post.
SDR Console tmp.rtf
(39.9 KiB) Downloaded 379 times
Cheers,
Roger.
Posted: Fri Aug 20, 2021 5:01 pm
G8VLR wrote: Fri Aug 20, 2021 4:32 pm Simon, it was in private messages but I have reattached it to this post.SDR Console tmp.rtf
Cheers,
Roger.
Thanks, that really helped.
