Page 3 of 4
Re: Program will not run
Posted: Thu Mar 10, 2022 6:41 am
OK,
Now I need to know what version of DirectX you have: Run this program. I really want the first page. I see that an important DirectX function isn't working on your computer.
I can also make a kit which pops up a message, but first show me this information.
Posted: Thu Mar 10, 2022 1:46 pm
by James_VA3JPX
Hi Simon, here is the DxDiag you requested.
James
Posted: Thu Mar 10, 2022 2:27 pm
I'll make a special kit just for you which will report the error in a popup message box. My guess is a lack of resources, we'll see.
Posted: Thu Mar 10, 2022 7:29 pm
Please run this kit - it adds diagnostics which you see with DebugView.
Here's an example of my output.
Code: Select all
[17400] WorldMap: E:\Open\SimonsWorldMap\SimonsWorldMap\WorldMapWnd.cpp 1266 compatibleRenderTarget() 7502.666016 x 1218.000000
[17400] WorldMap: E:\Open\SimonsWorldMap\SimonsWorldMap\WorldMapWnd.cpp 1276 Created
[17400] WorldMap: E:\Open\SimonsWorldMap\SimonsWorldMap\WorldMapWnd.cpp 1311 GetBitmap() x00000000 The operation completed successfully.
[17400] WorldMap, 19:28:32.454: Rotator> Starting thread
[17400] WorldMap, 19:28:32.454: Rotator> Setting priority to 'Below normal' (-1)
[17400] WorldMap, 19:28:32.454: Background> Starting thread
[17400] WorldMap, 19:28:32.454: Background> Setting priority to 'Below normal' (-1)
I want to see the output, you can save from the File menu in DebugView.
Posted: Thu Mar 10, 2022 8:24 pm
by James_VA3JPX
Ugh, now the program is crashing on startup. Here is the dump info.
James
Posted: Fri Mar 11, 2022 6:02 am
OK, Sorry - will have to make a kit and archive it all. Will do this today.
Posted: Fri Mar 11, 2022 6:14 am
So,
Sorry about this. Please run the kit below, send me the crash dump. I'll take it from there.
https://www.dropbox.com/s/v6ehvmh0jopgp ... 1.exe?dl=0
Posted: Fri Mar 11, 2022 3:15 pm
by James_VA3JPX
Thanks Simon, here is the dump info.
James
Posted: Sat Mar 12, 2022 7:18 am
OK,
It crashed during an error reporting call, my fault. Sadly this shows that we do have a problem with your computer's installation. In this kit I've added popup error message boxes, you will probably see two. I would like screenshots of these popups, they tell me all the info that's available.
here's a kit
Posted: Sat Mar 12, 2022 10:59 am
by James_VA3JPX
Good Morning Simon,
Here is the screen capture. Please note there is only one popup and it doesn't go away. I have to end the task in order to close the program.
James
