rx888 mk2 no receive
Posted: Fri Apr 09, 2021 10:11 am
by booncer
Hi There, new user,
I have installed my rx888 mk2 and the dependency's I have no signal on receive on either the hf or the vhf antennas.
SDR console seems to see the rx888 mk2 I'm wondering if there's any other drivers or settings i may have missed.
asus A15 usb 3.2 gen 2
microsoft c++ redistributables 2008 2010 2013 2015-2019 x86/x64
cyprus fx3
cyprus api
SDR console 3.0.27 x64
Regards
Mark
Re: rx888 mk2 no receive
Posted: Fri Apr 09, 2021 2:14 pm
by ukdx
Probably a silly question but have you gone into the radio menu, set HF attn to 0 and wound up the gains to max? Tools, options Performance, do you see any readings when it's running? Even if I turn down the gain to min and max attenuation to lose every last signal I can still see plenty of of FFT and CPU activity on the usage meter.
Posted: Fri Apr 09, 2021 3:21 pm
by booncer
thanks for the reply seems like the fft and the cpu is doing something, i dont see the att or the rf gains settings in the menu
Posted: Fri Apr 09, 2021 3:34 pm
by booncer
Posted: Fri Apr 09, 2021 6:01 pm
by booncer
appears to work in HDSDR
Posted: Fri Apr 09, 2021 9:33 pm
by bagmouse7
The screenshots title shows it was discovered as an RX666.
You should delete this and rediscover the radio as an RX888.
Good luck.
Posted: Sat Apr 10, 2021 11:21 am
by booncer
seems it works now after redetecting the driver for the rx888
thanks bagmouse7 you have a sharp eye
Posted: Fri Apr 23, 2021 4:18 pm
by everstar
While the MKII seems to be up and alive for me, it doesn't look like it is seeing any signals. Any thoughts?
Posted: Fri Apr 23, 2021 5:45 pm
by G4ZFQ
Does it work with HDSDR and the recommended DLL?
This is the main software the developer uses.
I'm not sure if Simon has checked the Mk 2 version?
73 Alan
Posted: Fri Apr 23, 2021 9:18 pm
by bagmouse7
The Mk 2 version works.
You have the HF gain set all the way up in that screenshot.
Set the gain down to 40 or 50.
Good luck.
