TX led on Linear after HL2
Posted: Thu Aug 19, 2021 5:23 pm
by G8VLR
Another issue has occurred in tx. I have a linear amp after the HL2 on which there is a tx led. When using SDRc once in a few transmissions the tx led stays lit, so I tried with Thetis and the issue doesn't exist then.
Regards,
Roger.
Re: TX led on Linear after HL2
Posted: Thu Aug 19, 2021 5:55 pm
G8VLR wrote: Thu Aug 19, 2021 5:23 pm
Regards,
Roger.
Roger,
You're really going to provide more info, for example how does SDR Console interface to the linear? What's the setup?
Posted: Fri Aug 20, 2021 11:17 am
by G8VLR
Hi Simon, the lead is screened with phono plugs on each end and plugged into the HL2 ptt socket and the ptt socket on the linear . The linear, an HLA 300, requires the ptt line to be taken to ground for transmit
Hope that's enough info.
Cheers,
Roger.
Posted: Thu Aug 26, 2021 5:41 pm
by G8VLR
Update on this issue: only when I use the tx button or the foot switch; if I use the tune button everything works as it should.
Cheers,
Roger.
Posted: Thu Aug 26, 2021 5:51 pm
G8VLR wrote: Thu Aug 26, 2021 5:41 pm
Cheers,
Roger.
Hah, not possible
- trust me.
This is now high on my list, I was wondering about RF. Although the LED on the amp is lit, is it actually in TX? From memory I doubt I have an option to key an external amp, will try to look at this tomorrow.
Posted: Thu Aug 26, 2021 8:00 pm
by G8VLR
Thanks Simon,
Although the tx led is lit in fault condition, it is receiving but with considerable attenuation.
Cheers,
Roger.
Posted: Fri Aug 27, 2021 5:46 am
OK,
I'm getting through my urgent list, aka legal stuff, with luck I'll dig out my HL2 today.
Posted: Tue Aug 31, 2021 3:24 pm
So,
HL2 dug out, please show me these options as set on your HL2. I'm now going to look through the code...
Posted: Tue Aug 31, 2021 3:42 pm
OK,
Thinking about this and reading the HL2 information, what is happening is that a TRX relay isn't switching properly, this must be the problem. The way I switch TX / RX / TX is the same, no matter whether you use a footswitch or VOX or click the big [TX] button.
I'll keep thinking.
Posted: Tue Aug 31, 2021 5:24 pm
by G8VLR
Okay Simon here are my settings:
