Allow config of max drive value
Posted: Sat Nov 06, 2021 10:08 pm
let's assume you are using the following configuration:
[TRX] ==max 5w==> [Power Amplifier] ==max 50w==> [ATU] ====> [Antenna]
My tuner will propably die if I would tune it with 50W so I set the drive slider to a low value. In order to prevent accidently alteration of this value above a certain point, it would be of benefit to be able to configure a "max. drive power level" for tuning and maybe as well as for normal transmission somewhere in the config.
If I would for example set the "max. drive power level" to 40 and would then move the slider to 50, it immediately moves back to 40.
Thanks and 73
odie
Thanks and 73
odie
