Tune signal
Posted: Sun Dec 26, 2021 8:31 am
by dl2sba
Hi Forum
I cannot find any information regarding the signal used when I press "TUNE" in USB mode.
In the settings I can only find the option pulses/steady tone ...
Where can I control the tone frequency and level used in TUNE mode?
//Dietmar
Re: Tune signal
Posted: Sun Dec 26, 2021 10:13 am
Frequency is fixed, level set by the Drive control under the Tune button.
Re: Tune signal
Posted: Sun Dec 26, 2021 1:09 pm
by dl2sba
Yes the drive slider is known - but it does not affect the modulation level - at least the the Sepctrum window did not reflect this.
Which modulation frequency is used during TUNE mode?
Re: Tune signal
Posted: Mon Dec 27, 2021 7:03 am
dl2sba wrote: Sun Dec 26, 2021 1:09 pm Yes the drive slider is known - but it does not affect the modulation level - at least the the Sepctrum window did not reflect this.
500Hz frequency, 3dB below max. peak but the Drive reduces this level further.
Re: Tune signal
Posted: Mon Dec 27, 2021 4:04 pm
by dl2sba
Great tnx fr info ...
Re: Tune signal
Posted: Mon Dec 27, 2021 4:16 pm
dl2sba wrote: Sun Dec 26, 2021 1:09 pm Yes the drive slider is known - but it does not affect the modulation level - at least the the Spectrum window did not reflect this.
Tone(s) generator is fully configurable for level, frequency and number of tones but don't forget the level is affected by the TX DSP Gain slider. See attachment.
Re: Tune signal
Posted: Mon Dec 27, 2021 4:58 pm
by dl2sba
@Max
Yes - for the TONE function I agree
The TUNE function, as I've learned now, has a fixed 500Hz tone with -3dB
@Simon
Maybe the same options as for the TONE 1 also for the TUNE signal in a future release?
Re: Tune signal
Posted: Mon Dec 27, 2021 5:39 pm
dl2sba wrote: Mon Dec 27, 2021 4:58 pm @Max
@Simon
No point I think.
Re: Tune signal
Posted: Mon Dec 27, 2021 8:13 pm
Simon G4ELI wrote: Mon Dec 27, 2021 5:39 pm
dl2sba wrote: Mon Dec 27, 2021 4:58 pm @Simon
No point I think.
The point is that the Tune signal is ONLY affected by Drive. I agree with Simon on that one. They are different and each has its own specific place/use. It's handy having Tune where you know that the level cannot be affected elsewhere in the processing chain.
