Hi Forum
I cannot find any information regarding the signal used when I press "TUNE" in USB mode.
In the settings I can only find the option pulses/steady tone ...
Where can I control the tone frequency and level used in TUNE mode?
//Dietmar
Tune signal
Re: Tune signal
Frequency is fixed, level set by the Drive control under the Tune button.
Re: Tune signal
Yes the drive slider is known - but it does not affect the modulation level - at least the the Sepctrum window did not reflect this.
Which modulation frequency is used during TUNE mode?
Dietmar, DL2SBA
Dietmar, DL2SBA
Re: Tune signal
500Hz frequency, 3dB below max. peak but the Drive reduces this level further.dl2sba wrote: Sun Dec 26, 2021 1:09 pm Yes the drive slider is known - but it does not affect the modulation level - at least the the Sepctrum window did not reflect this.
Re: Tune signal
Tone(s) generator is fully configurable for level, frequency and number of tones but don't forget the level is affected by the TX DSP Gain slider. See attachment.dl2sba wrote: Sun Dec 26, 2021 1:09 pm Yes the drive slider is known - but it does not affect the modulation level - at least the the Spectrum window did not reflect this.
Re: Tune signal
@Max
Yes - for the TONE function I agree
The TUNE function, as I've learned now, has a fixed 500Hz tone with -3dB
@Simon
Maybe the same options as for the TONE 1 also for the TUNE signal in a future release?
@Simon
Dietmar, DL2SBA
Dietmar, DL2SBA
Re: Tune signal
No point I think.dl2sba wrote: Mon Dec 27, 2021 4:58 pm @Max
@Simon
Re: Tune signal
The point is that the Tune signal is ONLY affected by Drive. I agree with Simon on that one. They are different and each has its own specific place/use. It's handy having Tune where you know that the level cannot be affected elsewhere in the processing chain.Simon G4ELI wrote: Mon Dec 27, 2021 5:39 pmNo point I think.dl2sba wrote: Mon Dec 27, 2021 4:58 pm @Simon
