SDRconsole RTL not working
Posted: Thu Apr 07, 2022 7:53 pm
by sdramateur
SDRplay, Pluto, Airspy, RTL-SDR 820 + E4000 are working in SDR# so RTL is using the zadig correct
SDRplay, Pluto, Airspy are working in SDRconsole
RTL-SDR did work older SDRconsole version but some mysterious way not get analyser action any more, SDRconsole hang, crashes need close SDRconsole manual.
In Radio configuration RTL = detected : Realtek RTL2838UHIDIR 00000001
I try several hours, i get lost in it, any hint will help
Re: SDRconsole RTL not working
Posted: Fri Apr 08, 2022 10:42 am
What frequency do you have set?
What OS version?
What is the first change to the machine after which SDRC did not work right?
What SDRC version?
What picture? (Debugging requires readable pictures showing configuration data.)
What error message, if any?
And what does rtlsdr have to do with analyzer? I thought it simply read a file. Did you change the format selection for saving the file for some reason? Did you change where the files are stored?
Are you a neat freak who cleans up directories to remove files you don't know what they do? (If so, reinstall SDRC.)
Posted: Fri Apr 08, 2022 10:21 pm
by sdramateur
jdow wrote: Fri Apr 08, 2022 10:42 am
same frequenty when using Airspy, pluto, sdrplay to test i use 95.000 Mhz
What OS version?
use F:/ drive like i always do or did before.
Windows 10
All of them old releases who where installed from 2018 or earlyer and the latest release i download today
No error no receive Only with RTL-SDR, all of them, 820 + E4000
the analyser window show if any signal is received but the waterfall is also empty :0
iam linux user aswell
i did remove all of them, old new, reboot, clean the register, reboot, i did 4 times,
And after that i open this topic
Under BUGS topic, more users not able get RTLSDR going in SDRC
To be sure, i install 3.1 for 5e time but now in the windows10 root on C:/ drive
Same, RTLSDR no receive, hang, SDRC not responding, take very long time for close/end SDRC.
Posted: Sat Apr 09, 2022 12:01 pm
sdramateur wrote: Fri Apr 08, 2022 10:21 pm
That's good - in range of the devices.
[quote"
What OS version?
Windows 10
Up to date?
Not a responsive answer. Look to changes from when it worked to when it doesn't work. For that matter what version are you trying to use.
Does it appear in the definitions? If so and you press stop does it flip to run and still produce nothing on the spectrum? (FWIW I have a half dozen of those dongles all working here on two different computers, one if which is absurdly weak and brand new. (It's an Intel NUC configuration.)
The spectrum window shows what? I don't give a damn about analyzer if the spectrum does not work. Crawl. walk, then try to run.
It can't be that which makes you a smartass. I also run Linux in a custom router, repository, email filter, etc. Some people compulsively delete files they do not understand. Their systems soon quit working. So I considered that option here due to EXTREME lack of information.
You also removed data from the appropriate subdirectory in %appdata%, as well?
While other users manage to do it correctly and have no problems. (That new machine has a Windows issue, I suspect. The rtlsdr dongles don't work on SDRSharp and work fine on SDRC. Go figure.)
3.1 - that's nice. What version - file date information? I can't seem to see it in your very informative screen capture you failed to post here. It must be the nature of the missing file.
(I likely have decades more experience than you do of being an asshole. Why not be informative so I can try to cooperate instead of being an asshole?)
Posted: Sat Apr 09, 2022 7:06 pm
by sdramateur
Windows 10 Home 21H1 19043.1526
The latest 3.1 download from website
SDR Console.exe 18-3-2022 - size = 25.729.792
I wrote in start post : Yes, it appear in the definitions
Yes
Do i need to look in the same spectrum i mention earlyer?
Thank you for nice friendly help.
- SDRCONSOLE_004.jpg (35.93 KiB) Viewed 16723 times
Posted: Sun Apr 10, 2022 12:26 pm
The spectrum is showing nothing. And you have the rtlsdr AGC on. And the frequency is set to an acceptable frequency. Does this dongle work with any other program? It's acting as if it's input is blown. I doubt any sound is coming out. Is that a rash assumption on my part or not?
Another possibility is that you have it setup to use frequency conversion. That could result in the dongle being pushed down to its inoperable frequency range. That should enable one of the dongle's HF modes. With nothing hooked up it might show nothing this way since the gain control is essentially gone in the direct sampling mode.
That's all I can think of at the moment.
edit: The version of libusb you are using might make a difference. I'll check earlier tomorrow to see if you answer and try to suggest ways to insert a different libusb version. They are very much "pick your set of bugs" tools. And they are about the only tool in town for this which is why they are hardwired into the rtlsdr.dll versions out there.
Posted: Mon Apr 11, 2022 8:27 am
by sdramateur
jdow wrote: Sun Apr 10, 2022 12:26 pm
RTLSDR hardware is working fine in :
SDR#
SDR++
GQRX
Cubic
SDRangel
OP25
DSDplus
GNUradio
Sigdigger, spectraview or under linux many others libusb or using soapy
Saying this,
i have in total 23x RTLSDR hardware from differ brands (you name one i have it) with differ chipsets so you could assume i have changed the hardware,
this handling/change was not needed because they all work fine in the other software from the long list
I try to copy drivers from or out SDR# but when done this, SDRconsole when startup give a error message, it did not find RTLSDR driver
So i dont know or get stuck what drivers need to be replaced.
BTW --- before replace any i first renamed the original driver to easy restore to original
i had the same sort issue when change from version 2.0 to first 3.0 versions, after some testing Simon found a bug that time.
maybe that old bug is back in town? (he not told me what is was)
May something privacy setting about a microfoon in windows, because SDRconsole is not in that list, while other programs are in that list............. ?
Just callout.
After done this all as mention above, i put my first start topic on this support board for HELP wanted.
Long story short,
3.1 is no longer working in my windows 10 i cant find. Are you able to give any advice, asking please?
Posted: Mon Apr 11, 2022 11:25 am
sdramateur wrote: Mon Apr 11, 2022 8:27 am
SDR#
SDR++
GQRX
Cubic
SDRangel
OP25
DSDplus
GNUradio
Noted, although I can't promise not to forget in a senior moment. (Getting ready for my 9th decade in a couple years.)
That problem is 32 bit (SDRSharp) vs 64 bit (SDRC).
Just callout.
I've been wondering that, too.
Long story short,
I am attaching a zip file with the two dlls I am successfully using.
I'm not sure about 3.1 not working. Didn't you say AirSpy was working? Make sure it remains working when you test the libusb in my attachment. Before copying the files in (which should be what you have anyway) rename the two existing files to something like rtlsdr.dll.bak so you can go backwards.
Something else that comes to mind is a need to run vcredist files in the "C:\Program Files\SDR-Radio.com (V3)\x64" folder. Have you tried rerunning them?
Another thing to look at is whether you have at some of Windoze er Windows security junk turned off.
Posted: Mon Apr 11, 2022 4:12 pm
by sdramateur
jdow wrote: Mon Apr 11, 2022 11:25 am
re-run or re-install again, and only this one did the trick RTLSDR = running
C:\Program Files\SDR-Radio.com (V3)\x64\VC_redist.x64.exe
Question:
How come?
BTW use SDR
12x RTLSDR differ brands (all)
6x Airspy-mini
2x Airspy-R2
2x Pluto
1x RSP1A
Running 4x PC + 5x raspberry + winhoos, linux.
From one oldi to other oldi, i forgive you the ashole part....... Thanks mate !
Posted: Tue Apr 12, 2022 10:52 am
Thank YOU for unassholing. It's easier for me to work in a more constructive atmosphere. Too much data is usually better than too little when trying to solve problems. {^_-} And I do get a kick out of helping other people when I can.
I am really glad I thought of that. I was really scraping the bottom of the barrel trying to get this solved. I have no problem with this. "Visual Studio" is my favorite computer game. So I tend to have all the DLLs in these packages and more installed without me thinking of it.
{^_^} Joanne
