Switch between radios
Posted: Mon May 27, 2024 12:20 pm
I use the SDR-Console V3.3 with two different radios.
1. Adalm-Pluto as RX+TX for my QO100 setup.
2. SDRplay RSP1A for observing local FM-repeater on 438MHz.
While switching between these radios I use previously stored custom layouts. This do restore the layout, but I have to manually set the frequency, mode and other parameter each time I switch the radio.
I wonder if this is the right way to do it? Or are there other options to handle the switch between different radio in a smoother way?
Thanks for every hint.
Hank, DB8BH
Hank, DB8BH
