Switch between radios
DB8BH
Unread post by DB8BH »
I use the SDR-Console V3.3 with two different radios.
1. Adalm-Pluto as RX+TX for my QO100 setup.
2. SDRplay RSP1A for observing local FM-repeater on 438MHz.
While switching between these radios I use previously stored custom layouts. This do restore the layout, but I have to manually set the frequency, mode and other parameter each time I switch the radio.
I wonder if this is the right way to do it? Or are there other options to handle the switch between different radio in a smoother way?
Thanks for every hint.
Hank, DB8BH
Re: Switch between radios
Use identities for this maybe?
DB8BH
Thank you for the quick response, Simon.
I wasn't aware of that feature. Just tried it and it does what I'm looking for, great.
So, question answered.
Thank's a lot
Hank, DB8BH
