V3.3 Build 3236 does not recogonize RSPdx-R2
Posted: Thu Aug 22, 2024 3:33 am
by W8GTX - BDM
Hello all. I'm hoping someone can point out what I'm missing/doing wrong. I have SDRuno V1.42 1710 installed, and it shows 3.15 API. Console is the latest Build, see pics below. SDR Console works with the radio, but it shows as "unknown", and features like antenna choice, IF/RF gain are missing, just the basics. Any ideas? Thanks
-Brian
Re: V3.3 Build 3236 does not recogonize RSPdx-R2
Posted: Thu Aug 22, 2024 11:10 am
by Maksym Kozub
Sorry if it sounds stupid to you, but just in case: are you sure you have a genuine RSPdx-R2? I have not heard about fake ones as yet, but I am pretty sure they will appear on the market at some point in time, if they have not appeared yet.
Posted: Thu Aug 22, 2024 11:48 am
by W8GTX - BDM
I purchased it from HRO a few days back
Posted: Thu Aug 22, 2024 11:56 pm
W8GTX - BDM wrote: Thu Aug 22, 2024 3:33 am Hello all. I'm hoping someone can point out what I'm missing/doing wrong. I have SDRuno V1.42 1710 installed, and it shows 3.15 API. Console is the latest Build, see pics below. SDR Console works with the radio, but it shows as "unknown", and features like antenna choice, IF/RF gain are missing, just the basics. Any ideas? Thanks
-Brian
Someone else has reported exactly same issues (unless that was you?) on the "other" IO Group for SDRC. Sounds like something to do with the new hardware that needs looking at by Simon?
Posted: Thu Aug 22, 2024 11:57 pm
Max wrote: Thu Aug 22, 2024 11:56 pm
-Brian
https://sdr-radio.groups.io/g/main/topi ... /107692908
Posted: Fri Aug 23, 2024 12:10 am
by W8GTX - BDM
-Brian
Max, thank you. I was getting ready to post this in that forum. Also, the Server does not work, most everything is grayed out
-Brian
Posted: Fri Aug 23, 2024 8:20 am
From the mailing list for someone else from Simon:
Go to the downloads, there's an updated DLL. Here's a direct link:
https://1drv.ms/u/s!AovWaZDu7HrdgZROs8p ... Q?e=wLK8zd
SDRPlay RSPdx-R2
May 22nd, 2024. This DLL supports the SDRplay RSPdx-R2, code-signed for safety.
In SDR Console: select Ribbon bar, Tools, Files, Installation to open the installation folder.
Close SDR Console.
Extract SDRSourceSDRplayV3.dll from the ZIP.
Replace SDRSourceSDRplayV3.dll with the new file from the ZIP.
Start SDR Console.
Simon Brown
https://g4eli.com
https://sdr-radio.com
https://sdr-radio.com/datv
Hoe this helps.
{^_^} (Gee, typing with a 16# cat climbing on my er kitty climbing lumps is difficult.)
Posted: Fri Aug 23, 2024 3:11 pm
by W8GTX - BDM
He responded to me on that other list, thanks, and that worked like a charm
-Brian
jdow wrote: Fri Aug 23, 2024 8:20 am From the mailing list for someone else from Simon:
SDRPlay RSPdx-R2
Close SDR Console.
Start SDR Console.
Simon Brown
https://g4eli.com
Hoe this helps.
Posted: Tue Jul 21, 2026 12:35 pm
by ea1cmp
SDRPlay RSPdx-R2
Close SDR Console.
Start SDR Console.
Simon Brown
https://g4eli.com
Hoe this helps.
Thanks to all.
I had the same problem and could solve it following this steps.
Posted: Fri Jul 24, 2026 1:30 pm
ea1cmp wrote: Tue Jul 21, 2026 12:35 pm Thanks to all.
Thhis is a very old thread. You should be using SDRC v3.4. This does not need the DLL replacing. It just works.
