TS-590SG control by SDRConsole is intermittent
Posted: Sun Oct 27, 2024 5:34 pm
by avigdor6
Hi, I am trying to use SDRconsole as a panadaptor with my Kenwood TS-590SG. The rig control via Omnirig works successfully with SDRUno. With SDRConsole there have been a few times when it worked, but most often I get "port busy". No clue why this is intermittent. I try to connect immediately after reboot. I would like it consistently to connect. Thanks...
Re: TS-590SG control by SDRConsole is intermittent
Posted: Sun Oct 27, 2024 8:13 pm
by WB2ZXJ
If you run into the Port Busy problem try this: close SDRConsole -- start up OmniRig or OmniRig Client -- then start
up SDRConsole. You should be good to go.
Barry
WB2ZXJ
