TS-590SG control by SDRConsole is intermittent
Hi, I am trying to use SDRconsole as a panadaptor with my Kenwood TS-590SG. The rig control via Omnirig works successfully with SDRUno. With SDRConsole there have been a few times when it worked, but most often I get "port busy". No clue why this is intermittent. I try to connect immediately after reboot. I would like it consistently to connect. Thanks...
- Snap31.jpg (16.03 KiB) Viewed 9296 times
Re: TS-590SG control by SDRConsole is intermittent
If you run into the Port Busy problem try this: close SDRConsole -- start up OmniRig or OmniRig Client -- then start
up SDRConsole. You should be good to go.
Barry
WB2ZXJ
Barry
WB2ZXJ
