LIME MINI USB testing TX on HF Bands
Posted: Wed Jan 01, 2025 6:51 pm
Hi Guys,
I'm a long time radio builder, and I'm planning a hybrid analog/digital RTX.
I am testing RF output with a spettrum analyzer using SDR Consolle with LIME MINI USB on the HF band TX (setting 3 MHZ Hf-TX)
In some bands, even if they are very rich in harmonics, the problem will be overcomed with a good filtering before RF amp.
But on some HF bands it is not possible to remove a spurious signal at only 500 KHz separation from the transmission frequency, you can see 2 attach images in the 7 MHz band.
Even setting everything to minimum like SW drive and TX doesn't change anything, the spurious frequencies remain the same.
Suggestion please ?
73 Arnaldo www.ik2nbu.com
Suggestion please ?
