Hi Guys,
I'm a long time radio builder, and I'm planning a hybrid analog/digital RTX.
I am testing RF output with a spettrum analyzer using SDR Consolle with LIME MINI USB on the HF band TX (setting 3 MHZ Hf-TX)
In some bands, even if they are very rich in harmonics, the problem will be overcomed with a good filtering before RF amp.
But on some HF bands it is not possible to remove a spurious signal at only 500 KHz separation from the transmission frequency, you can see 2 attach images in the 7 MHz band.
Even setting everything to minimum like SW drive and TX doesn't change anything, the spurious frequencies remain the same.
Suggestion please ?
73 Arnaldo www.ik2nbu.com
LIME MINI USB testing TX on HF Bands
- 7mhz_spury.jpg (246.44 KiB) Viewed 10396 times
- 7mhz_spectrum.jpg (264.57 KiB) Viewed 10396 times
Re: LIME MINI USB testing TX on HF Bands
Look at the available Lime options. I can't see them without connecting a Lime, I'm busy elsewhere atm.
Maybe show me the options you've selected?
I seem to remember there's a TX calibration somewhere.
Dear Simon,
my normal setup on LimeMini USB:
Bandwidth = 3 MHZ (HF-TX)
Drive Level = Minimun - 40 db / Max - 10 db level
Mode TX Half Duplex
Antenna: auto for both
Calibrate RX and TX passed
TX streaming : 0 ms
Test and measurements with TX in AM 50% carrier
I'll post the screenshots tomorrow.
I repeated with various levels of RF drive, the spurs are always there, only 2 bands, the 1.8 Mhz and 18 Mhz bands are saved which are clean (see 2 images).
All the other HF bands they have spurs very close typically to 500 Khz, and there is always a fixed spur at 30 MHz.
73 www.ik2nbu.com
Mode TX Half Duplex
TX streaming : 0 ms
73 www.ik2nbu.com
- 160_nice.jpg (243.19 KiB) Viewed 10373 times
- 18mhz_nice.jpg (247.88 KiB) Viewed 10373 times
Complete LIME screenshot,
the only error is the TX calibration, even with the maximum output drive level (0 db) it gives me a low drive signal message.
I found the way!
I did the TX calibration at 70 MHz and then I went back to HF. The spectrum result is completely different, and I can operate in HF with good mandatory low pass filters. There is no trace of spurious frequencies near the HF carrier. The trick was to do the calibration in VHF.
- after_cal_70_Mhz.jpg (265.88 KiB) Viewed 10341 times
- TX_Calibrate_70Mhz.jpg (414.79 KiB) Viewed 10341 times
