Pluto SDR "Failed to enumerate available contexts"
Posted: Sat Feb 01, 2025 5:43 pm
SDR Console version 3.3 build 3236.
I have a new Adlam Pluto just out of the box last week.
I am having problems with stopping and re-starting the Console.
On startup, "Select Radio > Definitions > Search Pluto SDR"
produces 3 instances. One with an IPv4 (192.168.2.1), one with an IPv6 (fe80::205:f7ff:fea0:3628), and one with URI=usb:x.x.x
I "Save", then I select the 192.168.2.1 instance since that is the Pluto default.
Console starts, and all is well...until I stop Console (Stop button in the Home Tab).
When I try to restart (Start button in the Home Tab), I get a failure with the message "Failed to enumerate available contexts"
Closing SDR Console and re-opening does not fix the issue. The only way is to again "Select Radio > Definitions > Search Pluto SDR"
Interestingly, the instances shown at failure, and those that replace them after a search and replace appear to be identical.
Attached Capture1.jpg = at failure.
Attached Capture.jpg = after search and replace.
A post on the Groups.io <https://sdr-radio.groups.io/g/main/topi ... 2#msg62316>
Suggests insufficient power to the Pluto SDR. I have tried powering from a USB3 port, adding an additional 1 amp supply to the 2nd USB port, and using a powered Belkin High speed USB hub (Belkin F5U233) between the USB3 port and the radio (with the extra power supply), all to no avail.
Any help would be appreciated.
Steve, k5dog
Steve, k5dog
