Understanding frequency
Posted: Fri Dec 26, 2025 10:44 am
I am trying to get my head around how my RTL-SDR handles frequencies.
I have the Nooelec NESDR SMArt v5 Bundle, described here: https://www.nooelec.com/store/sdr/sdr-r ... smart.html
The page tells me that it can handle a frequency range between 100kHz-1.75GHz.
- I assume that this is a theoretical frequency range, and that the actual frequency range received will depend on the antenna used?
- The RTL-SDR comes with 3 antennae, but no indication as to what frequency ranges they are good for:
a. Telescopic antenna mast (variable frequency); I assume this is the shiny silver one, but what frequency range?
b. 433MHz (ISM) antenna mast (fixed frequency); Does this mean it is good for only ONE frequency, or a range centred on this frequency
c. UHF antenna mast (fixed frequency); Google tells me that UHF is 300 megahertz (MHz) to 3 gigahertz (GHz), but since the RTL-SDR is rated at a maximum of 1.75GHz, this is the limit? - Do I need to worry about the antenna frequency bandwidth resolution. In other words, if my software selects a bandwidth of 3 KHz, does this also depend on my antenna?
