Understanding frequency
iantresman
Unread post by iantresman »
I am trying to get my head around how my RTL-SDR handles frequencies.
I have the Nooelec NESDR SMArt v5 Bundle, described here: https://www.nooelec.com/store/sdr/sdr-r ... smart.html
The page tells me that it can handle a frequency range between 100kHz-1.75GHz.
  1. I assume that this is a theoretical frequency range, and that the actual frequency range received will depend on the antenna used?
  2. The RTL-SDR comes with 3 antennae, but no indication as to what frequency ranges they are good for:
    a. Telescopic antenna mast (variable frequency); I assume this is the shiny silver one, but what frequency range?
    b. 433MHz (ISM) antenna mast (fixed frequency); Does this mean it is good for only ONE frequency, or a range centred on this frequency
    c. UHF antenna mast (fixed frequency); Google tells me that UHF is 300 megahertz (MHz) to 3 gigahertz (GHz), but since the RTL-SDR is rated at a maximum of 1.75GHz, this is the limit?
  3. Do I need to worry about the antenna frequency bandwidth resolution. In other words, if my software selects a bandwidth of 3 KHz, does this also depend on my antenna?
iantresman
Re: Understanding frequency
I found some information on the antennae that come with the Nooelec NESDR SMArt v5 Bundle:
  • Telescopic antenna: frequencies vary depending on the set length.
  • Long black antenna: 433 MHz, 3dBi
  • Short black antenna: 800-2200 MHz, 3G, 5dBi
You've asked questions here that cover an awful lot of ground so rather than try and answer it myself I've entered your questions on ChatGPT which has made a pretty good job of answering. See the attached PDF which I think answers your questions very well. Anything more specific come back here and ask again.
You don't need to obsess too much about the exact antenna length for receiving until you get to critical listening, i.e. extracting every last drop of signal. For example, if you want to receive long distance signals on VHF/UHF, then you are talking about a multi-element antenna cut specifically for a band (say the 2m amateur band) which is directional with high gain and is steerable, such as a Yagi etc.
For general "just see what's about" type listening you will get by just with the telescopic antenna for now and if you want to try optimising it, use the rule in the PDF I've attached which gives a quick rough formula for tuning/adjusting the antenna length to approximately 1/4 wavelength which is the ideal for a small whip antenna.
If you are looking at receiving much lower frequencies than VHF/UHF with an RTL-SDR, shortwave broadcast bands for example, then you will need to start looking at antennas optimised for LF/MF/HF (which broadly speaking covers a range of 500kHz to 30MHz) then you need to look at putting up a length of wire several meters long or, possibly a better bet for a "one antenna covers all" (receive purposes only), a broad-range loop antenna like this:
https://midsussexars.org.uk/feature-art ... -amplifier
The big issue these days with antennas is trying to place the receiving element away from noise sources. Just trying to use a telescopic whip indoors right next door to local noisy power supplies etc that are to be found in most home, will likely lead to disappointment as a lot of the time you will struggle to extract a signal that exceeds the local noise level. Nevertheless, those noise source tend on the whole to produce noise at the LF/MF/HF frequencies (up to 30MHz) and above this you stand more chance with the whip of receiving some local signals, like ham radio repeaters on 2m/70cm for example, or VHF FM broadcast radio signals
ChatGPT-RTL-SDR Antenna Frequency Range.pdf
(184.06 KiB) Downloaded 104 times
iantresman
Thanks for that, I haven't asked AI myself because I don't feel I have the right vocabulary to know how to ask the right questions!
