AM AGC
Posted: Mon Aug 10, 2020 6:47 pm
Use the carrier for AM AGC, not demodulated audio.
Re: AM AGC
Posted: Fri Aug 14, 2020 9:20 pm
by GaryG4977
I have some interference covering most of the AM broadcast band. Usually, with constant speech or music, the AGC works fine but if there is a second or more of 'dead air' time the interference noise level increases due to the current AGC method. The carrier level does stay constant so carrier AGC should cure that one annoyance with AM.
Thanks for all the work you put into this large project!
GaryG
Re: AM AGC
Posted: Sat Aug 22, 2020 12:15 pm
by Robert111
Via Simon: "Use the carrier for AM AGC, not demodulated audio."
How, please, does one switch between them ? (Doesn't seem to be in the AGC choices/pull downs ?)
Bob
Re: AM AGC
Posted: Sat Aug 22, 2020 12:25 pm
Robert111 wrote: Sat Aug 22, 2020 12:15 pm
Bob
Carrier AGC for AM is in 3.0.25, at present you can't switch. IMO Carrier AGC is much better.
Re: AM AGC
Posted: Wed Aug 26, 2020 9:10 am
by jpsa
Does this request include carrier-based AM squelch?
John
Re: AM AGC
Posted: Wed Aug 26, 2020 10:01 am
jpsa wrote: Wed Aug 26, 2020 9:10 am
John
No, at the moment I don't plan to add this until 3.1 is released. I'm working on something else at the moment and am trying to keep Q4 2020 clear for some experimental UI coding.
