AM AGC
AM AGC
Use the carrier for AM AGC, not demodulated audio.
GaryG4977
Re: AM AGC
Unread post by GaryG4977 »
I have some interference covering most of the AM broadcast band. Usually, with constant speech or music, the AGC works fine but if there is a second or more of 'dead air' time the interference noise level increases due to the current AGC method. The carrier level does stay constant so carrier AGC should cure that one annoyance with AM.
Thanks for all the work you put into this large project!
GaryG
Robert111
Re: AM AGC
Unread post by Robert111 »
Via Simon: "Use the carrier for AM AGC, not demodulated audio."
How, please, does one switch between them ? (Doesn't seem to be in the AGC choices/pull downs ?)
Bob
Re: AM AGC
Robert111 wrote: Sat Aug 22, 2020 12:15 pm Hello,
Bob
Carrier AGC for AM is in 3.0.25, at present you can't switch. IMO Carrier AGC is much better.
jpsa
Re: AM AGC
Unread post by jpsa »
Does this request include carrier-based AM squelch?
John
Re: AM AGC
jpsa wrote: Wed Aug 26, 2020 9:10 am Does this request include carrier-based AM squelch?
John
No, at the moment I don't plan to add this until 3.1 is released. I'm working on something else at the moment and am trying to keep Q4 2020 clear for some experimental UI coding.
