Version 3.0.36 spectrum problem
Posted: Mon Dec 14, 2020 11:33 pm
by G7JUR
Just installed the new release. The problem I have is Shaded will not stay enabled in the spectrum, after restart.
The odd thing is that when running on my laptop as a remote setup, this problem does not happen.
Philip G7JUR
Re: Version 3.0.36 spectrum problem
Posted: Tue Dec 15, 2020 8:42 pm
by BarneyBear65
I have the same problem with the spectrum shading is disabled after restart.
Re: Version 3.0.26 spectrum problem
Posted: Tue Dec 15, 2020 10:31 pm
by G7JUR
That's good. I did a clean install, still not working correctly.
Odd thing is that it works fine on my laptop.
Both computers running Windows 10 64 Bit
My desktop has a AMD processor, and the laptop has an Intel.
Philip G7JUR
Posted: Sun Jan 24, 2021 7:16 am
by yo3ihg
I can confirm this issue as well. It's happening on two laptops that I am using.
Vlad YO3IHG
Posted: Mon Jan 25, 2021 1:42 pm
by G3TDJ
Perhaps your CPU is classed as "low power" by SDRC. See the 3.0.26 Release Notes
viewtopic.php?t=604
...Changed definition of a low power CPU to include a CPU such as the Q8400 / Q9000 which does not have the SSE4.2 extended instructions.
If you have a low power CPU (see start of logfile) then on startup:
Spectrum shading is disabled,
A peek at the start of the log file will confirm
Posted: Tue Jan 26, 2021 6:43 am
I'll add an option to override the automatic Low Power computer setting.
Posted: Sat Jan 30, 2021 12:21 pm
by rainstar
sometimes sdrradio will crash under a specific condition:
select a memory. drag the interface to another signal using the waterfall that is possibly outside of the tunable range so that the previously tuned channel is no longer being decoded, even if it is
still selected. select "back".
Posted: Sat Feb 06, 2021 9:04 pm
Hi Rainstar, if your issue has nothing to do with the start of this thread dan please start a new post and give us some more details about your computer, radio, used freq's when this happens and screenshot(s) to clarify the issue. "Stealing" an existing thread in every forum, is a recipe to being ignored.
Posted: Fri Mar 26, 2021 10:36 pm
by G7JUR
Still having the same problem with version 3.0.37
Philip G7JUR
Posted: Fri Mar 26, 2021 10:38 pm
by G7JUR
Has this been added in version 3.0.37
Philip G7JUR
