Page 1 of 4
Program will not run
Posted: Tue Jan 26, 2021 1:42 am
by Mike VK7DMH
I have just downloaded and installed the world map program, all seems OK with the installation but when running the program Windows comes up with the message "Simons world map has stopped working a problem caused the program to stop working"
I have tried re-installing and re-starting with no success. I am using Windows 7 Ultimate on a HP Compaq computer (dated) but runs my SDR-Play with SDR-Console OK (latest update)
I hope that you will be able to help, 73 Mike VK7DMH
Re: Program will not run
Posted: Tue Jan 26, 2021 6:12 am
OK,
First I'll dig out a Windows 7 system and run it there. I've not seen this before, it can indicate a Windows problem but that doesn't make sense as Console runs. (SDRUno is different technology.)
Posted: Tue Jan 26, 2021 10:27 pm
by Mike VK7DMH
Thank you Simon, I would send you a screen shot if I knew how to attach it to this reply !
Posted: Wed Jan 27, 2021 6:09 am
Click 'Full Editor & Preview' below and you can add a file.
Posted: Wed Jan 27, 2021 8:50 pm
by Mike VK7DMH
Hope this works ,73 Mike.
Posted: Wed Jan 27, 2021 11:59 pm
by Mike VK7DMH
I used a USB stick and transferred the downloaded program from my station computer over to my laptop which runs Windows 10. No problems! installed OK and program runs perfectly.
This at least proves the download was not corrupted by my station PC, of coarse whats happening in Windows 7 is the problem.
73 Mike
Posted: Fri Jan 29, 2021 11:09 am
by G3TDJ
For what it's worth, the World Map runs fine here in Windows 7 Pro 32-bit (VMware VM)
Posted: Fri Jan 29, 2021 1:28 pm
Mike VK7DMH wrote: Wed Jan 27, 2021 8:50 pm
Is this 'real Windows' or a virtual host?
Posted: Fri Jan 29, 2021 10:10 pm
by Mike VK7DMH
Real Windows
Posted: Fri Feb 05, 2021 1:22 am
by Mike VK7DMH
I have been thinking that some other program I am running may be at conflict with Simon's program ? I run "Dimention 4" to synchronise for FT8 and "Qlock 1.91" to display world times,
could these be a problem. 73 Mike
