Using Line-1 out of SDRC to WSJTx Audio In causes Delay
G4ZFQ
Re: Using Line-1 out of SDRC to WSJTx Audio In causes Delay
Unread post by G4ZFQ »
I've now been running WSPR on a RTL dongle 24/7 with SDR Console 3.0.25 b1990/WSJT-X/Mushzenco for about 10 days.
DT has not risen at all.
However, before that with an identical test DT rose to a few seconds overnight. It was not computer timing, other instances of WSPR were unaffected. They run for weeks between M$ updates.
I can not explain but it seems there can be intermittent problems with this setup.
73 Alan G4ZFQ
G4ZFQ wrote: Wed Jun 02, 2021 8:00 am I've now been running WSPR on a RTL dongle 24/7 with SDR Console 3.0.25 b1990/WSJT-X/Mushzenco for about 10 days.
73 Alan G4ZFQ
It's the difference in clocks between the SDR and PC, as simple as that. I'll explain later about a VAC trick I have enabled which we should disable for WSJT. Am now back firing on all cylinders.
KD7YZ Bob
Unread post by KD7YZ Bob »
Wonderful !
Simon to our rescue again , yeaaaaaahhhhh! :)
KD7YZ Bob EM88
