Test Team
NO6B
Re: Test Team
#51
Unread post by NO6B »
I'm a bit confused: I see this "Test Team" forum, but only passing mentions of a v3.0.26 SDRC. Is there another group somewhere for Test Team members?
m3ghe
Re: Test Team
#52
Unread post by m3ghe »
NO6B wrote: Wed Oct 28, 2020 6:54 am I'm a bit confused: I see this "Test Team" forum, but only passing mentions of a v3.0.26 SDRC. Is there another group somewhere for Test Team members?
Yes there a sub section in these forums.
If you can't see them it is because you haven't been added as a member.
Look at the first comment in the thread.
viewtopic.php?f=58&t=31#p85
Martin
m3ghe
IO92sc
G-QRP club 6129
4z1ao
Re: Test Team
#53
Unread post by 4z1ao »
Simon G4ELI wrote: Tue Aug 11, 2020 4:17 am A set of forums are reserved for the test team, if you are in the groups.io test team or wish to join the test team set a private message via this BB to me.
Members of the test team will see the Test Team category.
Simon, please transfer me (if not transferred yet) to this forum Test Team from groups.io test team (User Name: 4z1ao).
Thanks, 73.
Re: Test Team
#54
4z1ao wrote: Fri Nov 06, 2020 11:04 am
Thanks, 73.
Done.....
4z1ao
Re: Test Team
#55
G0OFE wrote: Fri Nov 06, 2020 11:42 am
Done.....
I've just arrived to this forum and am confused. I used to be a member at groups.io until lately. Can you direct me to the downloads of beta versions for testing of the 3.0.26 (if at all exists). Should I get a special permission for that from Simon?
73 Isaac 4Z1AO
Re: Test Team
#56
Isaak,
Have PMed you.
BarneyBear65
Re: Test Team
#57
Unread post by BarneyBear65 »
Hi, can you subscribe me to to the test kits? the registered user name on IO-Groups is: Barney Breet. Thank you.
Re: Test Team
#58
Barney, you should now be able to see the Test team forum.
W1RS
Re: Test Team
#59
Unread post by W1RS »
Please add me to the Test Team. I was a member of the groups.io Test Team as W1RS and didn't realize I needed to re-subscribe to the new forum TT to see the sub-forums. Thank you!
4X1RV
Re: Test Team
#60
Unread post by 4X1RV »
Hi
Please add me..
4X1RV
