Using With Airspy HF+ Discovery
Robert11
Unread post by Robert11 »
Sorry, but I realize that I just posted this in the wrong Forum, and that it should be here, probably.
In the select radio screen, it will not accept the Airpy HF+ Discovery, even though it shows as a choice, and I have the Definitions, etc. set.
But, it works fine and will accept if I plug and unplug the USB cable output from the unit a few times.
Any thoughts ?
Bob
N6ATC
Re: Using With Airspy HF+ Discovery
Unread post by N6ATC »
Hi, Bob:
Given the behavior you describe, I would immediately suspect that cable.
Have you tried a different cable or a different port?
Curt - N6ATC
