HI Simon, Folks,
I tried to install the RX-888 mkII on my PC, used the dedicated USB Drivers and installed the latest SDR-Console version.
Also followed the "USB recommendations....
BUT...after selection RX-888 in the local RX menue it tries to load the driver and after a while it crashes with "SDR Console.exe caused access vialation in module c:\....SDR-Radio.com(V3)\SDR SoureRX888.dl at...
Re-installed SDR-Console, Re-installed USB Drives...always the same...hmmm
Its on a USB 3 port..."Blue connector"..followed USB recommendations.
What could be the reason? Intel I9-9900k, 64Bit Windows 10...hmmm
Errorlog and Screenshot is attached.
73s
Bernie
RX-888 Cant install driver under Windows 10
Bernie_himself
- errorlog.xml
- (238.45 KiB) Downloaded 178 times
Re: RX-888 Cant install driver under Windows 10
Ah the RX-888 USB issue ...
Bernie,
try disconnecting and reconnecting (physical USB cable remove) from the RX-888. It looks like the OS has not seen the RX-888. If I reboot my system (seldom) I have the same issue! The OS does not see the RX-888 and then nothing works (in regard to the RX-888)
Hope this helps, cheers & 73
Hauke
Bernie,
Hauke
