Simon, is this feature still on the request (wish) list? We discussed it earlier this year but then the discussion died down.
Thanks...
Receiver Un-squelch Indicator
Re: Receiver Un-squelch Indicator
It is now !
Might be worth documenting the request properly in this thread.
Here is he original post:
During wild-land fire season I have Console running with 6 receivers defined to monitor the various fire agencies in the area. I have them all un-muted (but squelched) all of the time. But once in a while one, or more, receivers will get a bit more noise or an off-carrier signal that causes the squelch to start popping. But I cannot tell which of the 6 receivers is doing this. So I have to either mute all and then un-mute one at a time or select each receiver and tighten up the squelch. It would be nice to have a visual indicator for each receiver when the squelch is open. Maybe a simulated LED in the signal meter. Then I could just select the receiver with the indicator flashing and tighten the squelch on it.
Thanks again Simon for your great work...
Attached is an example of how I would like the indicator to be deployed. Look at the S meter fro receiver #4, the red dot...
I'd prefer to have it like this (receiver 6) - on my PCs the receiver pane slows down SDR Console too much.
Simon, is there just not enough interest in this from others?
Wildland fire season is about to startup again (not sure it ends with the lack of rain on the west coast) and I will be using my setup with 6 fire channels being monitored. Sure would be nice to have an un-squelched indicator.
Let me know if I should just stop bugging you about this. And thanks again for all the other great features!
Hi,ka6fub wrote: Sat Apr 23, 2022 7:39 pm Simon, is there just not enough interest in this from others?
I've been taking a break for a few weeks, the first break from coding in at least 21 years. I'll look at this now and see if there's a simple solution.
OK,
I think I have this working, for now you'll see the Squelch text as per the attachment. If not squelched then no text.
What about forget the text and have red speaker crossed through for "squelched" and green speaker with no cross through for squelch opened? And a lot bigger too. With maybe 16 receivers in RX matrix, that text will be very small?
Understood it's work in progress so sure you already have other display ideas eventually.
I'll make a kit for the test team today or tomorrow to it can be tested. Colour of icon is a problem, for example I'm slightly colour blind.Max wrote: Sun Apr 24, 2022 9:25 pm What about forget the text and have red speaker crossed through for "squelched" and green speaker with no cross through for squelch opened? And a lot bigger too. With maybe 16 receivers in RX matrix, that text will be very small?
