can it add support for new version omnirig v2.1
davidchien0327
Unread post by davidchien0327 »
Dear Sir
is it possible to add support for new omnirig v2.1 ? http://www.hb9ryz.ch/omnirig/index.html
is it can support 4 rig and poi time can less time 100ms (20ms) i think it will reduce time when do the switch from satellites RX/TX
because sometimes radio no response when press both button especially when external radio start and enable Doppler function
we had test yaesu 991A and icom ic705 with omnirig v1.19
thanks
Thomas Berner
Re: can it add support for new version omnirig v2.1
Unread post by Thomas Berner »
I would also be interested in Omnirig V2.1 support, since my current setup (Yaesu FT450D + SCU17) seems to have a problem with Omnirig 1.19. As soon as the connection is active both PTT and FSK signals are activated permanently.
This happens too when using HDSDR with Omnirig 1.19 but not with Omnirig 2.1.
If anyone knows more about this it would be helpful.
Thomas
DF1TB
davidchien0327 wrote: Fri Jun 25, 2021 11:05 am Dear Sir
thanks
Have you tried Omnirig v2.1?
Thomas Berner
my issue with SCU17 + FT450D is solved, one need to use SCU17 drivers from YAESU website. Newer drivers caused the problem with FSK/PTT activation with Omnirig 2.1.
I also tried Omnirig 1.19 with SDR console .28 version, you get various error messages and the connection fails.
But for me Omnirig 1.19 support is sufficient now.
Thomas
DF1TB
maby
Unread post by maby »
By all measn support Omnirig 2, but please don't remove Omnirig 1 support! At the moment, the number of applications supporting Omnirig 2 is still low and, although it has some nice features, it is not a viable replacement. One of the other SDR programs in circulation made the decison to switch to OR2 and had to issue a new version shortly afterwards that reinstated the OR1 option!
Martin (G8FXC)
If I ever support OmniRig 2 then it'll be a user-configurable option.
At present - no plans at all.
