Thanks for a great s/w tool, I have been able to get tx as well as rx to QO-100 working and learned a lot along the way.
My rx set up is:
pluto -> 1m patch lead ->bias T -> 25m satellite coax -> sat finder -> 1m patch lead -> 4 channel Octagon lnb -> 80cm Technomate Mesh Satellite Dish.
I think the sat finder adds about 12 dB gain but does little else. The dish is on a scaffold pole in an old garden umbrella stand so I can move it fairly easily (this is relevant!).
I tend to check the CW beacon signal level when I switch on, just as a system sanity check. I set the rx to use manual gain 40 dB, so that I dont get caught out by AGC. I have 2 Octagon lnbs. On 23/1/21, I measured -55.3 and -56.2 dBm and on 13/4/21, after nearly 3 months of no use, I measured -54.8 and -56.0 dBm. So fairly stable. I was using sdr console v3.0.26.
On 20/4/21, I downloaded and installed v3.0.27. Towards the end of April, I moved the dish about 4m. After peaking the CW beacon, the highest level I measured was -60dBm.
In early May, I re-installed v3.0.26. No change - levels still ~-60dBm. However, I think I have read on the main website that reverting to an older version is not guaranteed to work and I didn't do a full un-install new, install old, so it seems quite possible that newer (v3.0.27) libraries may have been lurking and been used by the older (v3.0.26) application?
Today, I have moved the dish back to its original position and measured the level -62.4 dBm (strangely low), and then returned it to its "new" position, again measuring -60.8 dBm (vs -54.8 dBm).
Is there any known software related reason that could account for these missing 6 dB?
AFAIK, I haven't changed any other rx settings and with 30+ dB SNR, I dont think the rx filter bandwidth should matter (I dont think I've changed it anyway).
Is there a common mistake I could have made?
Has the iio library updated ADC scaling values?
6 dB is always a suspicious number for me.
I would be grateful for any helpful suggestions, thank you.
73s
Rob,
M5RAO
My missing 6 dBs
Jump to
- SDR-Radio.com
- ↳ Forums
- ↳ Bugs
- ↳ Computer Talk
- ↳ Developer News
- ↳ 💾 Download
- ↳ Kits, Release Notes
- ↳ Requests
- ↳ General Radio Topics
- ↳ SDR Chat
- ↳ Simon's World Map
- Console
- ↳ General
- ↳ V2
- ↳ SDR Television
- ↳ Analyser
- ↳ External Radio
- ↳ Interfacing
- ↳ Satellites
- ↳ Transmit
- ↳ Videos
- Server
- ↳ General
- ↳ Server Status
- Radios
- ↳ Other
- ↳ Afedri
- ↳ Airspy
- ↳ ANAN (hpsdr)
- ↳ Andrus
- ↳ Cross Country Wireless
- ↳ DXpatrol
- ↳ ELAD DUO Transceiver
- ↳ ELAD S1/S2/S3/DUOr
- ↳ Ettus Research
- ↳ hackRF
- ↳ Hermes-Lite 2
- ↳ ICOM r8600
- ↳ Lime Microsystems
- ↳ NUAND
- ↳ Perseus
- ↳ Pluto
- ↳ Red Pitaya/Stemlab
- ↳ RFspace
- ↳ RTL/SDR
- ↳ SDRplay
- ↳ Softrock
- ↳ WiNRADiO
- 3rd Party
- ↳ Other
- ↳ CW Skimmer
- ↳ DSD Plus
- ↳ Frequency Manager Suite
- ↳ go2MONITOR
- ↳ Ham Radio Deluxe
- ↳ MMSSTV, MMRTTY
- ↳ Virtual S-Meter
