Datafile Editor v3.1 editing out of sequence
SpE
Post by SpE »
When opening multiple sequential files that were recorded in SDRuno and editing them with the Datafile Editor, the final edited file is jumping unexpectedly when playing the edited wav file back in SDR Console v3.2. I suspect it could be chaining the original files out of order.
If you require the original files to investigate the problem further, I could upload them to a Google drive if needed.
The original SDRuno wav files play correctly in sequence with SDR Console, it appears that the problem is just with the Datafile Editor software.
Do you know of any software that could merge the individual 4GB files and create a single RF64 file as a workaround in the meantime?
Dave
