The trouble I am observing is if the DSP Panel is not displayed and I switch between one Favorite to another, is that it “remembers” the mode and sometimes the frequency of the previous Favorite.
For example, suppose you start SDR Console with the DSP Panel open and then select a Favorite configured for LSB at some frequency in the 40m band. Now close the DSP Panel and select another Favorite configured for USB at some frequency in the 20m band.
Initially, the frequency, waterfall, and mode will change as expected. However, if you change frequency, there are two scenarios of dysfunction depending on how you change frequency.
The first scenario is suppose you first click on the title bar of SDR Console so as to bring the window into focus so that you can change frequency with the arrow keys. The moment you hit the arrow key, the mode and frequency will revert back to that of the previously used Favorite but the waterfall will stay in the correct frequency range.
The second scenario is suppose you instead immediately click on the waterfall to change frequency. In this scenario, the frequency will change as expected but the mode will revert back to that of the previously used Favorite. Also, if you hold down the CTRL key to manually enter a frequency change, the same thing will happen.
Neither of the above described scenarios will occur and Favorites will work as expected if the DSP Panel is simply open when switching between Favorites.
I am not sure if this observed behavior is a user error and/or misunderstanding, an SDR Console bug, an SDR Console feature
