I have an odd question which may be quibbling but is more likely just me having an improper setting somewhere.
I am using the DX Cluster window, with spots on display above the waterfall. Now, ujsually when I go to a band in the default favourites list, it will display that entire sub band from left to right (i.e. CW 14.000 - 14.095 ish).
However, when clicking on a spot on the DX Cluster, the lower half of the 20M band shifts to the middle of the screen, showing frequencies below 14 Mhz in the left hand portion of the spectrum display. In some cases it puts 14.050 on the left side. I see there is the gray slider on the very bottom to select range. But that doesn't seem to resolve this permanently, as when I select a spot on any given band, the range changes back to non-amateur-band ranges.
Is there a way for me to lock in place those amateur bands so when I click on a spot the same range is displayed every time?
Scott N1IA
Freq Span When Clicking Spots on DX Clujster
Re: Freq Span When Clicking Spots on DX Clujster
I believe I have found the resolution to my plight. In the upper right of the program, there is a gear icon. Click on it, then Program Options appears. Under Tuning, General, the radio button "no action" should be selected for "when the active receiver is not visible". This took me forever to figure out, but it is holding so far. 73 de Scott N1IA
