Test case 24.915 MHz ham radio FT8 frequency and WSJT-X, V2.2.2
Received audio to speaker or virtual cable is mushy/distorted. The audio spectrum of received signals on the WSJT-X waterfall appear mushy and poorly defined. Signals will not decode. Changed SDR to an SDR-IQ. Signals are clearly defined on the WSJT waterfall and all signals are decoded. Using SDR Sharp with Airspy R2 and WSJT-X decodes FT8 fine...so the issue does appear to be with V3, likely settings.
I have tried reinstalling the software and adjusting all the settings I can find but there is no change. Does anyone have any suggestions? I purchased the Airspy R2 for weak signal VHF/UHF meteor scatter and Es propagation.
Thank You
Mike K7PI
