Scheduler Recording, a minor bug?
AJ6DT
Post by AJ6DT »
I'd like to report what appears to be a minor bug in the Scheduler Recording dialog window.
When creating a new scheduler definition, the list of events does not populate until I mess with the Title text box. Before messing with the Title box, I cannot get the event list to populate even if I wait for a very long time, or if I force the window to redraw, switch apps, etc. As soon as I alter the Title text or even just enter and leave the Title box using the tab key, the event list populates immediately.
Attached are a sequence of screenshots showing (1) a completed definition with an empty event list, (2) after selecting the Title box, (3) immediately after tabbing away from the Title box, and (4) the event list now populated.
I also noticed that the Start button in the Data::Scheduler portion of the Rec/Playback ribbon is not greyed out when the scheduler is running.
I'm running SDRC V3.2 build 2731 32bit on ARM (Pi-4). I cannot check whether this issue is resolved in the Beta versions of 3.3 because they don't install on the Pi.
Thank you for creating the absolute best SDR app ever.
a complete scheduler definition, no events are listed
selecting the Title text box
tabbed away from the Title
now the events are listed
