Hi All,
I've been using Pluto with Sdr Console for QO100 for a couple of months now and thought I had an issue with tx drift, but it turns out that although beacon lock appears to to function, over time the frequency drifts by as much as 2KHz. I'm sure I have the locking procedure right but the drift is real.
I use a windows 10 laptop with the latest version of console with a usb connection to the Adalm Pluto. My lnb is the Bullseye which appears to be working well. Has anyone else had a similar issue and is there a fix?
Regards,
Roger. (G8VLR).
Beacon lock for QO100
Re: Beacon lock for QO100
I have used the beacon lock without any drift for a number of years.
David M0TGC
Glad it's working for you David, but as I explained in my post it isn't working properly for me.
Let's see a screenshot.G8VLR wrote: Wed Oct 11, 2023 11:02 pm Glad it's working for you David, but as I explained in my post it isn't working properly for me.
The problem is now a massive 20kHz shift and I suspect a hardware issue and to eliminate the software from the problem I completely removed console with Revo and then after a reboot, reinstalled it. The problem persists so I have taken the Pluto and the new 40MHz reference oscillator out of the box and will test seperately.
Regards,
Roger. (G8VLR)
Regards,
Roger. (G8VLR)
Is your QO100 down converter GPS locked? If not 1 ppm out of 10 GHz is 10 kHz. And 1 ppm is VERY small drift for unmodified down converters, I hear tell.
