(the switcher humps are the 50v psu for my 2m amp... i'm working on it
Sounds more like a hardware issue? What is your PC motherboard, memory, GPU? Did you check minimum hardware requirements, although if running Win 11 I doubt if you are underpowered:K1FSY wrote: Mon Oct 09, 2023 3:29 pm Hello again! I have another report which happens occasionally when I have the SDR console unfocused and behind other windows, but not minimized. After some length of time (usually long) I return to the console and find that a lot of the widgets have disappeared and aren't redrawn. The screenshot below shows what is missing. Buttons and the TX/RX frequency come back if I mouse over them (presumably because of the mouseover effects), but in order to get the frequency ribbons to redraw it requires a minimize and restore. Minimize/restore always fixes all of the buttons. Using Windows 11.
It's a strange one. I think there was a report of something similar by another user some time ago but I do believe that was a bug that Simon fixed and never heard of it since.K1FSY wrote: Tue Oct 10, 2023 1:25 am I'm running a fairly modern computer with an nvidia card and recent drivers. I think it mostly happens after the system turns off the screen and locks and has to be unlocked. I haven't seen this happen with any other software that i typically leave open such as web browsers, jtdx, etc,
I know - and I don't know exactly why this happens.K1FSY wrote: Mon Oct 09, 2023 3:29 pm Hello again! I have another report which happens occasionally when I have the SDR console unfocused and behind other windows, but not minimized. After some length of time (usually long) I return to the console and find that a lot of the widgets have disappeared and aren't redrawn. The screenshot below shows what is missing. Buttons and the TX/RX frequency come back if I mouse over them (presumably because of the mouseover effects), but in order to get the frequency ribbons to redraw it requires a minimize and restore. Minimize/restore always fixes all of the buttons. Using Windows 11.
(the switcher humps are the 50v psu for my 2m amp... i'm working on it![]()
I may have solved this problem!Simon G4ELI wrote: Thu Oct 12, 2023 5:15 amI know - and I don't know exactly why this happens.K1FSY wrote: Mon Oct 09, 2023 3:29 pm Hello again! I have another report which happens occasionally when I have the SDR console unfocused and behind other windows, but not minimized. After some length of time (usually long) I return to the console and find that a lot of the widgets have disappeared and aren't redrawn. The screenshot below shows what is missing. Buttons and the TX/RX frequency come back if I mouse over them (presumably because of the mouseover effects), but in order to get the frequency ribbons to redraw it requires a minimize and restore. Minimize/restore always fixes all of the buttons. Using Windows 11.
