Hi all!
I attempted to run console (latest version) this morning without success. I’m running an Apache labs anan 7000 dle mkii(also now known as mkiii) that was delivered last July with a new chipset. The radio also requires a special protocol 2 to run with the new chipset, which I have working beautifully in Thetis.
When I launch console, the radio is recognized but when I press “start” it locks up and console crashes.
Does anyone have any thoughts or have you had success running console with the new chipset?
Thanks
Doug
Kb2uka
Anan 7000 dle mkii new chipset and firmware
Re: Anan 7000 dle mkii new chipset and firmware
Ah,Kb2uka wrote: Sat Feb 04, 2023 1:37 pm Hi all!
Thanks
Doug
Kb2uka
OK - soon I must revisit the ANAN code to fix this, it's been a while since I ran the ANAN.
Hello Doug,
If it has the new chipset then it is a MK III or not?
I run a 7K MK II (prot 2) without any problems.
Btw a first start, also after installing a new SDRC version, can take a few minutes. Proberbly the virusscanner busy in the background. Did you wait long enough?
Sometimes rediscovering the ANAN helps.
Regards, Leon
Regards, Leon
