Layout Help
steelgtr
Re: Layout Help
#11
Unread post by steelgtr »
Thanks again, I ordered SDRplay SDRplay RSPdx today
Re: Layout Help
#12
If you were primarily interested in LF/MF/HF then I would have strongly recommended the HF+ Discovery as being the superior choice, but if you also want VHF/UHF coverage then the RSPdx is the best option of the SDR Play lineup to go for (IMHO).
Anyway, it should be a big step up from the RTL-SDR for sure. Have fun with it.
steelgtr
Re: Layout Help
#13
Thanks, Max. I didn't see that in the states our HRO stores.
Screenshot 02-02-2024 07.35.43.jpg (305.49 KiB) Viewed 2968 times
steelgtr
Re: Layout Help
#14
Back on topic: How do I get this S meter vs the black one?
https://scontent-sjc3-1.xx.fbcdn.net/v/ ... e=65C290F1
Re: Layout Help
#15
steelgtr wrote: Fri Feb 02, 2024 3:35 pm Thanks, Max. I didn't see that in the states our HRO stores.
Airspy HF+ Discovery:
https://airspy.com/airspy-hf-discovery/
Just be aware of lower sampling bandwidth (912kHz) compared to the SDR Play devices, but if you are concentrating on LF/MF/HF listening, especially if you are a serious DXer one band at a time then this is pretty much unsurpassed at the price.
RSPdx more of an "allrounder" which also gives listening on VHF/UHF. I believe it's also reasonable on the AM bands unlike some of their other models. I am sure it will be perfectly OK for you unless you have a very strong AM broadcast station near you.
Re: Layout Help
#16
steelgtr wrote: Fri Feb 02, 2024 3:50 pm Back on topic: How do I get this S meter vs the black one?
See picture:
steelgtr
Re: Layout Help
#17
Screenshot 02-02-2024 15.18.12.jpg (723.42 KiB) Viewed 2924 times
Max wrote: Fri Feb 02, 2024 8:49 pm
See picture:
I'm running 3.2 so maybe that's why I don't have that.
bob
Re: Layout Help
#18
steelgtr wrote: Fri Feb 02, 2024 11:12 pm
bob
Ah, explains much. TBH I would never bother with the "Release" version of SDRC. Always use the latest Beta:
No need to uninstall anything. Just install over the top of 3.2.
The Beta that is posted on the website (linked above) has always been thoroughly tested by the Test Team for usually several weeks before it's posted for download. I can assure you it's not only totally safe to run but also highly recommended because there are actually bug fixes and many other features that are not in 3.2.
Good luck.
steelgtr
Re: Layout Help
#19
Max wrote: Fri Feb 02, 2024 8:47 pm
I got my RSPdx today but SDR console is not seeing it? SDRuno does tho?
thx
bob
Re: Layout Help
#20
steelgtr wrote: Sat Feb 03, 2024 12:10 am
thx
bob
Hello Bob. Did you install the Beta of SDR Console as I suggested (3.3). I understand that there have been some recent issue detecting the RSPdx in version 3.2.
Also make sure that the RSPdx is fed ideally from a USB port on your PC, but if not, from a powered USB hub. I understand there can also be some issues from lack of power to SDR Play receivers, so needs a good supply of power to the USB input. You could also try different USB cables that might help.
However, it's most likely a software issue so definitely try the 3.3 Beta.
