Change default volume setting
Greg6498
Unread post by Greg6498 »
Hello all!
I am using SDR Radio with Ergo4 and my Elad S3. I've noticed that every time I switch bands in favorites the volume defaults to 50%. This means when I schedule recordings that require a different band and higher audio, the audio on the new band is 50% when I want it to always be at 75%.
How can I change this default Volume setting from 50 to 75 so that it always defaults to 75%? This is a real problem for me!
Thanks in advance,
Greg N4WVE
Re: Change default volume setting
Greg6498 wrote: Sat Aug 17, 2024 12:56 am How can I change this default Volume setting from 50 to 75 so that it always defaults to 75%? This is a real problem for me!
Thanks in advance,
Greg N4WVE
Two options:
1: Recall Favourite, change volume level and then "Update" that Favourite with the new volume level. Do this for each Favourite in turn. It's not quite as painful as it sounds unless you have hundreds of Favourites!
2: In Favourites tab, left hand end, see the option of "Selection". Untick "Apply Level", then the stored volume level will not be recalled when selecting a Favourite.
https://www.sdr-radio.com/Favourites
