I'm using the latest version of SDR-Console V3, and whenever it is running the screen doesn't turn off after the 30 minute idle time set in Window's "Power & sleep" settings. If Console isn't running, the screen turns off as expected when the system is idle.
Is there a Console option that needs to be changed so that it doesn't prevent the screen from turning off when it's idle? I usually run WSPR overnight and there's no reason for the screen to be on when I'm not there.
Screen Doesn't Turn Off When SDR-Console is Running
Re: Screen Doesn't Turn Off When SDR-Console is Running
Yes,
Ribbon Bar, Tools, Disable Screensaver.
That worked. Thanks Simon.
