Vox
Also known as ADALM-PLUTO.
F6EXV
Vox
Unread post by F6EXV »
Hi all
Just joined the forum !
Using SDR Console version 3.4, and trying to configure it to do FT8 with MSHV.
When I set line 1 for transmit and for receive, the Pluto will go transmit erractically (with MSHV not opened). Bursts of emissions, apparently without any power out occur.
Where should I look to solve this ?
F6EXV
Re: Vox
800 views, not a single reply ?
Re: Vox
I've moved this to the Pluto subforum, perhaps you may be more likely to get an answer there.
Re: Vox
F6EXV wrote: Sat Mar 22, 2025 8:43 am 800 views, not a single reply ?
Turn around here is not guaranteed to be instantaneous. Like most other people I have other things to do than sit here all day waiting for questions. There is a chance you might get a better response attaching an unedited screenshot of SDRC showing the TX windows. That will make your settings plain to see. I have also heard remarks that TX does not work without a microphone attached even if you are not using it.
