SDRConsoleV3.3 with RSPduo not saving Tuner selection
ON4AOI
Unread post by ON4AOI »
Hi All,
maybe I am doing something wrong but the tuner is not stored when I create Favourites?
I setup and stored Tuner A for 367.080MHz that is connected to my PTRX-9700 for 1296Mhz and via MAP65 setup to QMAP/MAP65
I setup and stored Tuner B for 40.680 MHz via VBAudiocable to JTDX and this is also working perfect
BUT
All is stored perfect except the Tuner selection is this a bug or did I forget something to do ?
73 Guy ON4AOI
Re: SDRConsoleV3.3 with RSPduo not saving Tuner selection
ON4AOI wrote: Sun Mar 30, 2025 9:22 am All is stored perfect except the Tuner selection is this a bug or did I forget something to do ?
I don't fully understand what you mean by "Tuner selection". Maybe some screen shots would help to describe the issue?
I guess you are referring to "Receivers", so two different receivers, each with audio routed differently? Yes, Favourites should store those OK.
Firstly I would try update to SDRC v3.4 Beta. It's fully tested and working. You don't say how old your version of v3,3 is?
Regarding the RSP Duo, there is no facility in SDRC to use both of the receivers in the Duo, only one can be used at a time.
https://www.sdr-radio.com/sdrplay#RSPduo
