SDR Switching and RF Sensing Linear Amp Question
đź’Ą A general forum for topics not directly linked to SDR.
2E0JFS
Unread post by 2E0JFS »
I have a small linear for working base station.
My portable setup is now modular, based around a G90 and an RSPDxR2 SDR and Console 3.4 it works amazingly well all held together with Omnirig.
/P I'm out and about running from 1W to 10w in the countryside with various home brew Antennas
But at home an SDR Switch stops the linear from destroying the SDR which is does really well as in a recommended setup the amp sits on the Antenna switching output
However the PTT based Xeigu amp isn't that great .
I do have an RM broadband amp and low pass filter, but I am anxious that the amp will stay in TX after the PTT switch has opened the RX. ...as this amp is RF Sensing
Does anyone have an experience of this please or any suggestions? ....
Re: SDR Switching and RF Sensing Linear Amp Question
I use a Receiver Front End Protector, my SDR’s are on separate antennas from the TXR antenna. No relays clacking, just silence!
https://www.dxengineering.com/parts/dx ... zAYBIg6EtP
Array Solutions used to have one also, but it’s discontinued. Lots of cheap ones on Amazon/Ebay but at what level of protection?
Some of my antennas are only 8’ apart from the TX antenna.
2E0JFS
Yes, absolutely, I hadn't thought of that. I've used one once before at a field day didn't occur to me - Thank you for the suggestion.
This also looks to have the right idea - I have asked how much they cost - however - one does feel that if you have to ask how much something cost then it might cost a lot! :)
Thanks and 73 -
If you got room and a nearby wooded area, don’t overlook installing a RX antenna deep in the woods. RG6 (75 ohm) is cheap, RG11. (75 ohm also) can be found reasonably priced too. At our lake condo, I ran 350’ of RG11 away from all the condo units to an EFW, 9:1 Unun, and ~175’ of coated wire. My pneumatic tennis ball launcher allowed me to shoot a line up and over the tree tops and the antenna just rests atop the branches. Very quiet location and awesome S/N ratios.
7
2E0JFS
Oh Kriss,
I wish. I can get deep into the woods ....but I'm there with a camping table and a folding chair and lots of batteries.
Suburbia and adventure portable only for me I'm afraid.
