SDR Television does not start
PH5HP
Post by PH5HP »
I installed SDR Television and I hooked up my Pluto SDR. I must be doing something wrong, because the program will not start. The Pluto can be found on COM3 I found out. No crashdump and no logfiles found.
I am using Windows 11 64 bit with an Intel I7 12700KF, 64GB RAM and a NVidea 1080 8GB videocard.
Any help would be appreciated.
Kind regards,
Henk - PH5HP
G4ZFQ
Re: SDR Television does not start
Post by G4ZFQ »
PH5HP
Post by PH5HP »
Thank you, Alan. But I did read there that this is the place to ask questions or report bugs. I have still no idea why the program will not start. I can see in the Process Explorer that it exists when I started it, but it disappears as fast as I start it from the Process Explorer.
Kind regards,
Henk - PH5HP
G4ZFQ
Post by G4ZFQ »
Yes but the question you ask is being discussed there
Alan
