IP pluto not working on latest Console build
Also known as ADALM-PLUTO.
MM0MGB
Unread post by MM0MGB »
I'm out of ideas, my pluto has an ethernet adapter and has worked through all versions of SDR console until the version bundled with the SDR television.I created new definitions as described but the program reports back no Pluto found at the address. Rolling back to V3.4 on the SDR console downloads page and all is well again but this version not compatible with SDR television. so V3.4 Build 3569 works but the latest on the SDR television page does not.
Is this a known issue and I have missed something I should do or is there a bug waiting to be fixed?
Andrew MM0MGB
Re: IP pluto not working on latest Console build
What's the date of the SDR Radio kit as shown when starting? With Beta #2 it should be OK, if not then please attach the logfile after searching for definitions.
Would he have to recreate the pluto definitions?
MM0MGB
Hi Simon, Indeed Beta #2 has addressed the issue and my pluto now working over the Lan. Thanks and keep doing the great work its appreciated by all the users.
