About BRICK 2 - 16 Bit
⭐ All other radios not in the list below
Alessandro55
Unread post by Alessandro55 »
Good evening, I purchased the BRICK A 16 BIT today and I also have 3 other SDRs including the Hermes Lite, since I use THETIS with the Hermes I wanted to use the same software with the BRICK 2 but which one to download?? Always the one from MIO BOT???, I also wanted to know which pins to solder to build the PTT, and instead regarding the P.S. if it can be activated from the connector, thanks.
Re: About BRICK 2 - 16 Bit
This forum is for SDR Console software, so you may not find what you are looking for here.
Alessandro55
Thanks, it was a try.😃😃
