Problem with favourites in quickstart bar
harrygeier
Unread post by harrygeier »
i have trouble to get some favourites into the quickstart on top . I can add them, they work..but after restarting , they are gone..
Is there anything i do wrong or is it a bug ?
V 3.4 3973
regards 73
Harry DL9NDW
Re: Problem with favourites in quickstart bar
harrygeier wrote: Thu Sep 17, 2026 9:10 am Hi,
V 3.4 3973
regards 73
Harry DL9NDW
Hi Harry,
Sorry - can't be done - yet. As favourites are loaded dynamically from an XML file, this happens after the Quick Access Toolbar is created. I'll see if there's a workaround.
A timer at startup and a button press message when the timer runs out? It's kinda crude. It's how I've made some other you have to be booted in order to boot sort of problems.
