Maybe someone with solid knowledge about USB3 drivers and HW can give me a hint about how I should proceed with my investigation and hopefully solving of the below described problem.
I had my RX-888 open in order to get +5V from the USB connector pins on the board (to power a small fan) by soldering a thin lead to the +5V and ground pins. When I started it again SDRC could not find the RX-888 and started behaving.
I had traffic flowing erratically but then SDRC crashed. Win10 does find the Cypress FX3 device but it disappears from Win10 when SDRC crashes. In that moment Win10 also gives an error message that an unknown USB device has been detected.
Cypress Control Center finds the RX-888 at first but it disappears there as well after the SDRC crashes. See attached screenshot. Cypress Control Center also finds the LIME and that maybe can be used as a comparison.
SDRC also leaves a "Please wait" error dump (screenshot enclosed, file too big to attach at this stage, can do later if will be of any help). It complains about the RX-666 DLL-file. Same in both Win7 and Win10. SDRC crashes by merely searching for a RX-666/RX-888.
The SDRC Server also crashes when searching for RX-666/RX-888.
SDRC does not crash when the RX-888 is attached to a USB2 port, it starts but it stutters a lot of cause.
I am afraid that it is a HW fault but hopes that it may be a FW fault that can be reprogrammed
Would be thankful for help in solving this.
73 / Ingolf, SM6FHZ
